intermittent airbag warning light on Auris 2008
Joe Drive
Hi i have had this to local garage 3 times and they cancel the error code and checked the connections under the seat but then when i reverse down my drive way the warning light comes on again stop car and clears could drive for a day or two then back on intermittent airbag warning light on Auris 2008 petrol  mot coming up soon need help please
Thanks in Advance
Joe
Thanks for quick Reply not sure will ask guys garage tomorrow
Thanks in advance
20 hours ago, FROSTYBALLS said:
What error code shows?
Hi thank guys were really helpful and they let take a picture of it
B1660
Thanks in Advance
B1660
Thanks in Advance
Hi any luck with the code please
as my Mot is coming up and i dont want to fail it
Thanks in Advance
B1660
Thanks in Advance
Haven't come across that code - hopefully Devon Aygo will be able to shed some light on it.
B1660 Indicates a fault in the Passenger airbag status telltale light on the dash.
"The passenger airbag ON/OFF indicator circuit consists of the centre airbag sensor assembly and the air conditioning control assembly (*1) or telltale light assembly (*2).
The passenger airbag ON/OFF indicator indicates the operation condition of the front passenger airbag and the front passenger side - side airbag.
DTC B1660/43 is recorded when a malfunction is detected in the passenger airbag ON/OFF indicator circuit"
The triggers are:
  • The centre airbag sensor assembly receives an open circuit signal, a short circuit to ground signal or a short circuit to B+ signal in the passenger airbag ON/OFF indicator circuit for 2 seconds.
  • Passenger airbag ON/OFF indicator malfunction
  • Centre airbag sensor assembly malfunction ( SRS ECU )
Potential trouble areas are:
  • Instrument panel wire
  • Air conditioning control assembly (Passenger airbag ON/OFF indicator) (*1)
  • Telltale light assembly (Passenger airbag ON/OFF indicator) (*2)
  • *1: H/B Automatic A/C
  • *2: S/D, H/B Manual A/C
Hi thanks qiuck reply and your answer could you please put it into layman terms or the Dumb Guide please
Thanks in advance
