1999 corolla running on 3 cylinders
Frazer763
I have a 1999 1.4 corolla its only running on 3 cylinders changed out the spark plugs with no joy, its getting a spark removed the spark plug again and found it was as dry as a bone not getting fuel How can I check to see if the injector is getting power ???
Not something I have done and unless someone else comes in with some good info,  suggest you look at some of the many Ytubes on finding the fault.
This one looks like a good place to start without specialist equipment.
https://www.youtube.com/watch?v=tA_E6X4ISgQ
you can measure the injectors resistance with a multimeter, check two of your injectors and compare them, take one good injector and see if it has the same resistance as the cylinder that dosent get fuel.
or you could swap an injector that you know is working into the not working cylinder.
Thanks for the help
 I swaped out injector 1 with 2 and fault was with injector, picked one up today in breakers yard car running grand but seal on injector 3 leaking removed injectors but seal damaged any idea's were I might pick up a set of seals living in Ireland
Again thanks for the help
I'd go to a dealership. Seals aren't too expensive compared to the other parts you'd have to buy.
In my experience you'll either go to a place like Euro Car Parts and buy a seal which may not be 100% correct for your car, or for £1/£2 more you could go direct to the dealer and buy seals that will be 100% correct and official for your vehicle.
I am basing this on how it is in the UK. I know from my aunt that dealerships in Ireland are "robbing b*****ds". But then again she thinks everyone is a robbing b*****d.
Thanks for the help
