Starlet Engine Performance & Specfications
crystalize
Common Starlet Engine Performance and Specfications:
Toyota Starlet Glanza V (EP91 1996-1999) / Toyota Starlet GT Turbo (EP82 1990-1995)
4EFTE Toyota Starlet Glanza V (1998, 1999)
Displacement: 1331CC
5 Speed Manual or Automatic
Turbocharged CT-9B
BHP: 135@6400RPM (96'97 Glanza V=133BHP)
TORQUE: 116@4800RPM
CR: 8:2:1
DOHC
4EFTE Toyota Starlet GT Turbo
Turbocharged CT-9A
BHP: 133@6400RPM
TORQUE: 116@4800RPM
CR: 8:2:1
DOHC
Toyota Starlet Reflet/SR/ and Common Variations
2E Carb Engine
Displacement: 1295CC
4 & 5 Speed Manual or Automatic
BHP: 65-82BHP depending on Year
Torque:Depending on Year
CR: 9:3:1
SOHC
4EFE
BHP: 75-99BHP depending on Year
Torque: Depending on Year
CR: 9:6:1
DOHC
Toyota Starlet Glanza S / Toyota Starlet Gi
4EFE
BHP: 80-99BHP Depending on Year
CR: 9:6:1
DOHC
Different ECU to normal Starlets
I'll more stuff as the days go by.
  • 1 year later...
ep71 in need of help hy had my ep71 for 5 months now ive left corsa standing and vtec there all full of ??? but sins i upped the boost to 17 psi my gear box has now cracked if some 1 has 1 plz let me no or where i can get 1 from ma be i can get it recon give me some info im currently running 155 bhp and it only ways 780 kg so you tel me about a week ago i raced my friends glansa v and left him for ?????? help i want to race
  • 2 months later...
I HAVE A TOYOTA STARLET REFLET F 1999 AT 90 OCT GAS
10 GALONS (FULL TANK) GIVES ME 420 KMS IN AVERAGE , SOMEBODY SAID TO ME THAT ENGINE MUST BE AROUND 500 KMS WITH FULL TANK, ¿IS THAT TRUTH?
MAYBE SOMETHING IS WRONG , WHAT COULD BE?
  • 2 months later...
hey,
Im new to all this car performace stuff but if anyone could give me some info
on how to mod my 9 el44 toyota paseo ? Someone told me i need half of the
starlets engine where the f*$k would i find that.
Sorry like i said new to all of this...i need a teacher lol
  • 1 year later...
i have a 1996 black glanza. 179.6bhp to the wheels.
front mount intercooler, big brakes, stripped interior, rear tints, lowerred 60mm, full sports exhaust, hks induction kit, tweaked turbo & boost. 14" slightly deep dish wheels. runs 14.3's down the 1/4 mile @ 99.7MPH
  • 2 months later...
Got a Photo?
  • 1 year later...
i have a glanza v. Do you a web site where i can get a tuned ecu. what other part can i add to up the power. Ive got a full blitz exhust system and induction kit. thanks j
  • 4 months later...
hi there im new to this , what is the power spec for the glanza V ep91 i can't seem to see it.... is 135 bhp the most powerful they make a glanza in .. im interested in buying one but was told they come with bigger brake than 135 ? is this true ??
hi
im also new here i got me a glanza v 1996 nearly aweek ago but i seem to be getting a really low boost at just a mear 4 psi is this right or should it be more?
thanks in advance
john
Sounds like your on low boost mate, theres a button on the dash with a turbo image on it, press that and see what happens. If your in low boost then you should see a little green light on the boost gauge in the dash, if in high boost the light will go out.
  • 2 months later...
lol
And the point of the above post is??
Turbocharged CT-9B
TORQUE: 116@4800RPM
CR: 8:2:1
DOHC
Turbocharged CT-9A
BHP: 133@6400RPM
TORQUE: 116@4800RPM
CR: 8:2:1
DOHC
2E Carb Engine
CR: 9:3:1
SOHC
4EFE
CR: 9:6:1
DOHC
4EFE
CR: 9:6:1
DOHC
hiya ive got a ep81/82 starlet import 1.3 2ee engine and its running 102bhp at the flywheel buts its fuel injection not carb wat ecu do you recon it is runing on if i used the glanza s ecu would it make a improvement thanks luke
  • 3 months later...
hi, ive got a starlet sportif 1.3, lookin at n/a tuning it for a lil more umph.... any ideas on what the best things to do are, couple of people have mentioned fitting shorter conrods and cams out of a 5e-fe engine.......... but im not really too sure, also, would fittin an ECU from the glanza s make any difference..... help?????? :S
The best mods are corolla manifold, panel airfilter, exhaust etc
if you are going to mess about with cams and conrods it would be easier to just put a 5efe in!
i think ill try that cheers........ is the corrola engine the 5e-fe lump..?
  • 7 months later...
  • 1 year later...
