Cola
Hou
This is really an eye opener! We all know that water is important but I've
never seen it written down like this before.
WATER
1. 75% of Americans are chronically dehydrated. (Likely applies to half
world
population.)
2. In 37% of Americans, the thirst mechanism is so weak that it is often
mistaken for hunger.
3. Even MILD dehydration will slow down one's metabolism as much as 3%.
4. One glass of water will shut down midnight hunger pangs for almost
100% of the dieters studied in a University of Washington.
5. Lack of water, the #1 trigger of daytime fatigue.
6. Preliminary research indicates that 8-10 glasses of water a day could
significantly ease back and joint pain for up to 80% of sufferers.
7. A mere 2% drop in body water can trigger fuzzy short-term memory, trouble
with basic math, and difficulty focusing on the computer screen or on a
printed page.
8. Drinking 5 glasses of water daily decreases the risk of colon cancer by
45%, plus it can slash the risk of breast cancer by 79%, and one is 50%
less likely to
develop bladder cancer. Are you drinking the amount of water you should
every day?
COKE
1. In many states (in the USA) the highway patrol carries two gallons of
Coke in the trunk to remove blood from the highway after a car accident.
2. You can put a T-bone steak in a bowl of coke and it will be gone in two days.
3. To clean a toilet: Pour a can of Coca-Cola into the toilet bowl and let the
"real thing" sit for one hour, then flush clean. The citric acid in Coke
removes stains
from vitreous china.
4. To remove rust spots from chrome car bumpers: Rub the bumper with a
rumpled-up piece of Reynolds Wrap aluminium foil dipped in Coca-Cola.
5. To clean corrosion from car Battery terminals: Pour a can of Coca-Cola
over the terminals to bubble away the corrosion.
6. To loosen a rusted bolt: Applying a cloth soaked in Coca-Cola to the rusted
bolt for several minutes.
7. To bake a moist ham: Empty a can of Coca-Cola into the baking pan, wrap
the ham in aluminium foil, and bake. Thirty minutes before the ham is
finished, remove the foil, allowing the drippings to mix with the Coke for
sumptuous brown
gravy.
8. To remove grease from clothes: Empty a can of coke into a load of
greasy clothes, add detergent, and run through a regular cycle. The
Coca-Cola
will help loosen grease stains. It will also clean road haze from your
windshield.
FOR YOUR INFORMATION:
1. The active ingredient in Coke is phosphoric acid. Its pH is 2.8. It will
dissolve a nail in about four days. Phosphoric acid also leaches calcium from
bones and is a
major contributor to the rising increase in osteoporosis.
2. To carry Coca-Cola syrup (the concentrate) the commercial truck must use
the Hazardous Material place cards reserved for highly corrosive materials.
3. The distributors of coke have been using it to clean the engines of their
trucks for about 20 years!
Now the question is, would YOU like a glass of water or coke?
I try to drink at least two pints per day.. dont really like water, tastes like mud or grass :huh: ..
Think youre supposed to drink 2 litres :blink: , nearly there.
As soon as I stopped drinking coke, I started to loose weight, stopped feeling knackered all the time, had less stomach bugs/colds etc.
Now I live on sparkling water instead! :thumbsup:
I go through many cans a day (diet Pepsi though, I think Coke is too harsh), it is the staple drink of the code-monkey after all!
I am always drinking water, only have coke every now and then for a change but I'll think twice about it after reading that I think!
you cant get a healthy cola drink im afraid. Artificial sweetners are one of the worst poisons we consume dialy.
Excerpts from: http://www.earthways.co.uk/aspartame.html
"ASPARTAME. In temperatures exceeding 86 degrees F. the wood alcohol in Aspartame converts to Formaldehyde, and then to Formic Acid. Patients with methanol toxicity caused by drinking 3-4 Diet Coke or Diet Pepsi per day, have been caused to have MS or Systemic Lupus symptoms. In Systemic Lupus and MS case triggers by Aspartame, the victim is unaware that Aspartame is the culprit but continued use, in the case of Lupus, can be life threatening. On stopping Aspartame these patients usually lose all or most of their symptoms. Unfortunately the disease cannot be reversed.
Symptoms of Aspartame Disease are: Fibromylagia symptoms, spasms, shooting pains, cramps, vertigo, numbness in the legs, dizziness, headaches, tinnitus, joint pain, depression, anxiety attacks, slurred speech, blurred vision, blindness and memory loss. Formaldehyde is classed with chemicals like ubiknic and Cyanide – DEADLY POISONS!
Kills as surely as the other two, only slower and causes all kinds of neurological problems. It changes the brain’s chemistry and is a reason for severe seizures. According to the College of Physicians, the Phenylalanine in Aspartame depletes Serotonin, and causes manic depression, panic attacks, rage and violence."
From: http://www.sweetpoison.com/aspartame-side-effects.html
Adverse reactions and side effects of aspartame include:
Eye
blindness in one or both eyes
decreased vision and/or other eye problems such as: blurring, bright flashes, squiggly lines, tunnel vision, decreased night vision
pain in one or both eyes
decreased tears
trouble with contact lenses
bulging eyes
Ear
tinnitus - ringing or buzzing sound
severe intolerance of noise
marked hearing impairment
Neurologic
epileptic seizures
headaches, migraines and some severe
dizziness, unsteadiness, both
confusion, memory loss, both
severe drowsiness and sleepiness
paresthesia or numbness of the limbs
severe slurring of speech
severe hyperactivity and restless legs
atypical facial pain
severe tremors
Psychological/Psychiatric
severe depression
irritability
aggression
anxiety
personality changes
insomnia
phobias
Chest
palpitations, tachycardia
shortness of breath
recent high blood pressure
Gastrointestinal
nausea
diarrhea, sometimes with blood in stools
abdominal pain
pain when swallowing
Skin and Allergies
itching without a rash
lip and mouth reactions
hives
aggravated respiratory allergies such as asthma
Endocrine and Metabolic
loss of control of diabetes
menstrual changes
marked thinning or loss of hair
marked weight loss
gradual weight gain
aggravated low blood sugar (hypoglycemia)
severe PMS
Other
frequency of voiding and burning during urination
excessive thirst, fluid retention, leg swelling, and bloating
increased susceptibility to infection
Additional Symptoms of Aspartame Toxicity include the most critical symptoms of all
death
irreversible brain damage
birth defects, including mental retardation
peptic ulcers
aspartame addiction and increased craving for sweets
hyperactivity in children
severe depression
aggressive behavior
suicidal tendencies
Aspartame may trigger, mimic, or cause the following illnesses:
Chronic Fatigue Syndrome
Epstein-Barr
Post-Polio Syndrome
Lyme Disease
Grave’s Disease
Meniere’s Disease
Alzheimer’s Disease
ALS
Epilepsy
Multiple Sclerosis (MS)
EMS
Hypothyroidism
Mercury sensitivity from Amalgam fillings
Fibromyalgia
Lupus
non-Hodgkins
Lymphoma
Attention Deficit Disorder (ADD)
For more info and also a list of what products aspartame is in (you'll be surprised!), check out http://www.mercola.com/article/aspartame/hidden_dangers.htm
Well I am going to have a can of coke this afternoon, because I am really tired and need the caffeine (I don't drink tea or coffee).
I don't think the coke will do too much harm as I only have a couple of cans a year.
Water is boring, I top it up with squash.
I think curry is worse for you anyway.
curry is good for you... spices kill of germs and strenghten the immune system :D
not too sure about the super hot ones but im sure a clear out every once in and while would be beneficial :D
