Windows Help
bhinderharminder
hi,
ive started up my computer today and i got a message saying "boot disc failure..insert system disc and press enter", ive had this message come up before about a week ago and all i did was i restarted my pc and it worked fine, ive tryed doing the same now but it dont work....HELP
CHEERS :thumbsup:
Make sure there is no disk in the CD or floppy drive,
Check the Hard drive is still connected.
If that fails - probably the hard disk has failed mate.
J
J
theres nothing in the cd and floppy drive, if the bios still see's the hdd dose it mean it has failed? even if i am getting these messages
Have you got your windows XP disk?
Try seeing if that detects or repairs the drive mate.
could be the boot sectors been corupted.
J
J
ok, will give that a try in a bit
cheers
J
cheers
ve got it working hurray, i changed unplugged the ide lead from the m/boad and put it into where the cd-rom ide lead was and put the cd-rom lead where the hdd was. (hope that makes sence).
I had that message a few times and I was going spare trying to figure out why... Until I noticed my USB memory stick plugged in the back. Didn't realise my PC was trying to boot from the stick!
Duhh! :huh:
Cheers,
Jim
boot from xp disc, click " R " for repair , at the dos prompt type "FIXBOOT" - without the " " , a new boot sector is written to the hard drive.
if this dont work press f8 , boot into safe mode and system restore to a time when all was ok. :thumbsup:
Glad you got it sorted mate - PC's can be gits to get working again once they fail.
Now you gotta keep an eye on your CD drive lol if that fail's then you know its the cable :thumbsup:
J
J
Thanks for the help chaps :thumbsup:
