Plastic Polish
cmarshall
whats the best way to get scratches out of plastic. Some little **** has keyed one of my lexus lights lust want to know if i can repair it, its not that deep, but run my nail over it and it can be felt, if that helps.
PVA Glue.....
Sorry, I'm sure someone will come over with a real answer soon enough.
In fact, call your local windscreen repair place, they may be able to use the same stuff that they use to fill chips in windscreens.
yeah, the windscreen repair stuff will do the job if it's a fairly deep scratch. If it's just surface scratching you can sand them off with a fairly fine grade wet and dry paper, then polish it with T-cut to restore the optical quality.
