Problem On Blitz Supercharger
hare
Hi everyone, i have a wierd problem with my Vlitz at the moment
Its a 1.5 VVTI
I imported the car from japan, which came with a Blitz Bolt on kit, which comes with Blitz Chipped ECu and the control box
As the car arrive engine check light was on and it couldnt rev properly,
FIrst i send it back to Toyota for a check
THe faul is
As i Rev up from 1 to 2nd and 3rd or when is underload say coming up a hill
From 2800 to 3500rpm at full throttle the car will ***** but after 3500rpm fault will go away and recv properly all the way to the red line
It came up with the code - fault in the VTTI system - and came to faulty VVTI solenoid, so they replaced but the light is still on
So there is still a fault there and they gave up checking and gave the car back so where else can i go?
Did a wiring check by checkin contunity from the plug at the solenoid to ECU. It seems to be fine
Has anyone check the volage for the two wires at the solenoid? which is a Red/Black and Red/White
I found there is 5 volt at the Red/Black wire and nothing on the red/white
I dont have a shop manual so i have no idea if there is power for red / white.
Comparing with at AE111 4age engine there should be power on both wires so ? ? ?
Also the engine check light has gone off all a sudden
I have unplugged at the solenoid and turn the ignition on and also started the car but now engine check light stays off?
IF its unplugged and i fire up the car, doesnt engine check light comes ON coz it will be check as no signal??
I took it out for a drive, still had it discounnted but no light comes on ? ? but the car still faults
Does anyone has any idea what can it be? ? ?
Coz i dont know where to start
It only happens at full throttle
if u rev it up slowly thu that rpm then say 4000rpm and floor it, it wont fault
I'd say its almost defininately your ecu, are you sure its not standard? not really sure if you can get it checked/sorted without lots of money. (sorry im not much help)
i meant the way it's been mapped, not the physical ecu by the way.
the ECU is a upgraded ECU from Blitz,I tried to open the box but I can't make it,it's really tight.
I might finally have the APEXi power FC,but I want to do all the check I can before I order the new ECU.
