Show
Immobiliser Problem
#1
Posted 12 July 2006 - 09:17 PM
#2
Posted 19 July 2006 - 09:25 PM
If the button on the fob is white then ignor all i have just posted.
#3
Posted 22 July 2006 - 08:06 AM
Thanks for the reply. I haven't had chance to try this out yet and will let you know how I get on. I have looked at the fuses but can't remember seeing a dome fuse. The button on the key fob is black. I'm new to this forum so I hope I've posted this correctly.Take the cover off the fuse box under the bonnet then remove the dome fuse then press and hold down the black button on the alarm fob and at the same time refit the fuse. If that dosnt work you can try to Remove the glove box and you should see the alarm and immobiliser ecus. The earth wire should be rouited to the ecu bracket or under the heater box. It is a black wire with a ring termnal on the end of it. First disconect the battery then the earth wire. secondly reconect the battery then the earth wire. This should reset the ecu.
#4
Posted 23 July 2006 - 07:59 PM
dont make things so complicated . the same thing happened to me and the solution is :
the alarm system needs resetting.......put the alarm back in its original setting and do the following
Disconnect Negative battery terminal leaving positive connected.
(Make sure drivers window is down as car may lock)
Put key in ignition and turn on, Leave on.
Reconnect battery terminal.
Switch off ignition and remove key.
Press black button and hold for ten seconds.
Alarm should work.
#5
Posted 23 March 2009 - 11:26 AM
there is alot behind the glove compartment - can you please help locate ecus - xhat size how many? there is actually a black wire hanging lose - could thid be the culprt?
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Latest Comments
More
