Rear Disc On My Vitz
vitz06
i have a squeak on the rear sounds like comming from rear disc : jacked the car up took wheel off and noticed the studs move slightly and what lookslike two screws missing ( same on both sides ) any ideas please :thumbsup:
happens over bumps and if ( when u jack wheel up ) you move the wheel slightly
Pictures would make answering this question/query a lot easier mate :thumbsup:
Squeaks are usually rubbing of two surfaces where they require lubrication. This could be the tools/spare wheel in the back? Suspension/springs? Discs a bit wet and scraping something? Just guesses as usually discs catching on something would be a scraping noise. Is it only over bumps? Round corners? At certain speeds? Increase frequency with speed? etc. :P Sorry to not be much use just gathering information so that others can more easily help you :)
