Window Tints Removal
TRIGGER
:D Hi all, can someone tell me the easiest and best way to remove my window tints on my rear windows and little side windows, thx all :thumbsup: :D .
Should be able to pull the tint off quite easily.
Do it slowly (and use a heat gun if you can) though or you'll end up with a window covered in glue that takes a lot of effort to clean off!
I tried using a hairdryer (didn't have a heat gun) and that didn't make any difference to just pulling it off, guess it couldn't get hot enough.
I found that if you pull it off the window and try to keep the angle between the film you've removed and the window as shallow as possible the glue doesn't stick to the glass much :)
Sticky stuff remover removes any remaining glue quite well, but leaves its own residue so you need to clean the glass after.
Pull it off, wipe the glass with thinners, then dry it and use glass gleaner.
