Mission - Get Jim A Hdtv.... :)
Jimlad
All good TV's but check out the contrast ratios. Most of those posted are either 800:1 or 1000:1. The digimax i posted has a 1200:1 ratio which gives a much much better picture quality and seeing as HDTV is all about picture quality - nuff said :thumbsup::lol:
Also that Digimax is by far the cheapest around ;)
Ok....
so I've more or less narrowed it down to these 3...
http://www.directtvs.co.uk/Mirai_32_Inch_H...1/version-1.asp
http://www.directtvs.co.uk/Viewpia_LC-32IE...E22/version.asp
http://www.misco.co.uk/productinformation/...ch%20LCD-TV.htm
So out of these three... which is best? 2nd one because it has more connections and is 1200:1 ??
Or the first one because it has more features, like picture in picture etc??
HELP!.... :)
Look for LG or Samsung TVs as they are the best/most upto date features ........ you want it to display 1080p/1080i and have multi HDMI slots :thumbsup: !
Using an xbox 360 the graphics are immense :drool::drool:
No point spending £600 on a **** tv when you can spend an extra couple of hundred and get something decent and TRUE HD ...........
:thumbsup: !
Not sure about the others but I wouldn't get a goodmans. I've had two before and neither of them lasted longer than a few years.
I know Acoustic Solutions do really good stereo's, not heard anything about there TV's.
cool ? good service ?
How long did delivery take please :D ? I want it like now/yesterday :P
Used the Matercard and it was delivered within a couple of days :thumbsup:
Toshiba
I think its this for me.
That's who I used for our 37 inch :thumbsup:HERE
We've got the 32" version of that TV :thumbsup:
Jim have a look on the AV Forums and in particular this thread. I saved nearly £180 when I got mine from Currys just by entering a few codes ;)
Ordered me tv... ordered next day delivery, so should be here wednesday? :)
32 inch HD Ready TV including luxury glass stand and gold plated HDMI cable
The 1000:1 contrast ratio and 550 cd/m2 brightness and Digital Noise Reduction (DNR) gives you a natural colour balance, resulting in a crystal clear, realistic image. With digital audio and 'Super Bass' you can enjoy the cinematic audio experience too.
Features
Screen Size : 32" (81cm)
Panel Resolution : 1366 x 768
Aspect Ratio : 16:9
Number of Pixels : 1.05 million
Viewing Angle : 176° (H) / 176° (V)
Response Time : 8 ms
Contrast Ratio : 1000 : 1
Brightness : 550 cd/m2
Max. Colours: 16.7 million
Color Depth: 24-bit
Supported Timing: 480i / 480p / 576i / 576p / HDTV (720i / 720p / 1080i)
Tuner System: PAL, SECAM, NTSC
Teletext Memory: supported
Picture In Picture: supported
Additional Features: Stand Type / VESA Mounting
Weight: 15.0 Kg
2 year pick up and return warranty
Connections
1 x HDMI
1 x RF
1 x Component
2 x SCART
2 x AV+R/L
1 x S-Video R/L
1 x VGA PC Input
1 x RCA Stereo
1 x 3.5mm stereo jack
It has picture in picture whatever that is! Just like in BTTF II ?? ... lol.
Good choice :thumbsup: !
PiP (Picture in picture) allows you to watch two different channels at the same time. You select the channel you want to watch then press the PiP button and then a small box will popup with another channel in it. You can change the channel on both and also switch audio from one to the other ........ great for footie if the missus wants to watch something else :thumbsup: !
