Rubber For Headlamp
navygm
Anyone knows from where I can buy (except toyota agent) the sealing rubber from the lens to the headlamp?? cause I need these urgently and the agent hasn't got in stock :angry: as usual!
thanks
they should be able to get one in two to three days though. think youll struggle to get one from any where else.
as a temp fix you could try some silicon sealer
with DHL they told me a week!! impressive customer service! ;)
or else I'm trying to find some kind of sealer like the one used in the headlamp..
some ideas??
some ideas??
Silicon sealer (Instant gasket)................available at most diy stores :thumbsup:
If you are on about the bit i think you are (where u may need to seal if you opened it up to spray it black/remove the 'fried egg') then i'm pretty sure it is only held together with silicone sealant anyway which you can get at most DIY stores. Obviously make sure you get the clear stuff and then its just a simple application
yes actually I sprayed them black and came fabolous!
the sealant that they had was like a sticky chewing gum :) but when I opened them it was all black with dirt and stuff like that...
Now I sealed it with normal silicone, just left the silicone to dry half way, then put back the lens of the headlamp..
also I resprayed the bumpers due to some scratches...i think they came well, didnt fit them yet..
if someone knows how I can post some pics that would help cause I dont know how
thanks
