Radio Not Working(dead) Cd's Are Ok.
kleo
Radio is Toyota OEM 58806, everything was working fine yesterday, started the car today no power to the radio, no lights, no button functions & no display but the CD player works when I insert a CD. RADIO, ECU-ACC & AM fuses checked and OK, everything else in the car works and I have tried disconnecting the battery(which has reset the clock).
If you have an electric aerial, that might have broken the continuity in the aerial cable. That's what happened to mine. Had to remove the electric aerial unit to find the fault.
I have a virtually brand new (Car covered approx. 1K miles when removed) 58806 if you need one.
Its a fixed aerial, replaced about one month ago, it was split.
I was looking to replace it with an after market one, pm me a price for your unit.
regards
