Cd Changer Interface
Micheal
Is it possible to connect a CD changer to a TNS700??
Thanks,
Micheal
Yes (I believe) - because the iPod connection kit (which I have had fitted & works) plugs into the CD changer 'ole and I know get screens clearly designed for a CD changer... Suspect your freindly Mr T garage can tell you what model & price & fitting cost - then I'd see who else does one cheaper...
I asked my dealer this (due to pick mine up on Friday) - as a dealer fit option it's something like £5-600.
The parts guy couldn't remember when they last sold 1 & said that I could probably get an aftermarket 1 fitted for 1/2 that price.
Mind you the single disc one fitted is MP3 compatible so you can rip lots of albums to 1 CD & thereby eliminate the need.
Thanks guys for your help on this. Basically I took my CD changer out of my old avensis and wondered could I reuse it or should i sell it.
Thanks,
Micheal
I have a T180 with I believe the TNS700 system and you don't need a multi changer if you have a computer as the TNS700 plays mp3's which means a few hundred tracks on each CD
