Help Request
charadam
The connection has come away from the rear side window aerial.
I have bought the "special" - means expensive - conductive glue to stick it back.
Unfortunately, it is not obvious where it had been attached and there is a risk of connecting to the wrong area of the aerial printed circuit.
Could some kind person post a picture, taken from the outside?
Or advise in some other way?
Thanks,
Charles
Thanks,
Charles
Not sure what year your car is but see if the attachment helps.
Fitter
Thanks for the illustration, unfortunately it doesn't really help.
The car is an 07 T3X estate and does not have the satnav, so only one connector is bonded to the window aerial.
But thanks again for trying.
