Help
gizzard
This might not be the best place for a technical discussion on the board but my e-mails keep bouncing that are sent to admin:
icocnsupport+tocuk@googlemail.com on 31/03/2010 11:04
The message reached the recipient's e-mail system, but delivery was refused.
I can’t edit my profile as it says:
[#1026] You are not permitted to modify all or some of your profile information.
Is this normal?
Giz
I think (i could be wrong tho) that you have to post on the forums before you are able to edit your profile...
Think you've got it as I'm up and running now.
Cheers,
Giz
