Cruise Control
-Ub3R-
Can aftermarket cruise control be fitted to the aygo?
Preferably a unit that can be taken out of the car and put into my next car.
All for less than £200?
You could give this company a try...............Not sure that it will be in your budget though!
http://howard-may.co.uk/4555.html
There areseveral companies that sell after market cruise controls............Google is your friend!
Red Yaris 54 is right to suggest Google but I think you will find the cost is approx £500 fitted - and if your car is less than three years old your warranty may be vulnerable. Best check with your dealer.
Not a chance at under £200 I think, they take a while to fit too!
Kingo :thumbsup:
I've got a Waeco MS-50 system in my Car, paid about €149 for it and did the fitting myself.
Works like a carm, but I HATE the way the controls look, so I'm building new ones myself.
  • 4 years later...
I also want to build the Waeco MS-50 cruise control into my Toyota Aygo 2005. This is no drive-by-wire car so I have to install a servo motor thats controlling the throttle and a sensor for measuring the vehicle speed. I have a question about the last sensor.
Can somebody tell me if the speedometer of a Toyota Aygo 2005 has a VSS (Vehicle Speed Signal) input from the ECU? If so, can this be used by the Waeco MS-50 control unit instead of installing a speedsensor?
We fitted the Conrad Anderson system, easy fit and works fine.
