Whining Noise From Wheels Of Aygo
lor67
Hi there can anyone help a lady in distress, my 06 diesel aygo has developed a whining type noise from the front wheels, any ideas will be appreciated.
First of all you know this is a MR2 forum?
I think the problem could be a few things but i would reccomend taking it to a garage to be loked at.
1. Possibly the brake pads... sometimes they can whine, if the whining comes, gets worse or goes away when you brake it is probably that and nothing to worry about.
2. It could be the pads being worn as sometimes they have a metal tag on them that rubs on the disc when they become too worn, if this is the case you might be able to see it touching the disc and the pads would need to be changed.
3. Possibly the CV joint... if the rubber boot has torn it could be running dry as the grease could have leaked out.
