Need Help Anybody ...someone Shed Some Light......
BigDougz
My Corolla has started idling up and down on its own between 1500rpm and up to 2000rpm very fast .....Its a 16 16v 4A-FE..... Need to know what it could possiblly be before i got the Breakers tomarrow... The EML is NOT on btw....
Any body shed some light please cause im at wits end ..... help greatly appericated
I had a similar fault with a transit turned out to be the throttle pedal, try checking the throttle pedal position sensor.
