1995 With 22Re Engine
Patagualian
Hi everyone...... Looking for some info on this problem: engine will start if I link Bat+ to Fp in Diagnosis sockets. Engine stops when removed. Where is the relevant relay, (which would appear from this to be at fault,) located? :help:
Also, Alternator running at 16volts (when finally started.) Internal regulator gone? :help:
