Head Gasket Blown Suspected!
Nav786
hi, what are the suspected sign of head gasket blown, today my car when we replaced water with antifreeze mixed came up with a bit of boiling white foam does that mean the head gasket is gone and how much estimated will this cost?
I guess it would foam up if you had put the water and coolant in when the engine was still hot.
