Want To Change Gear Knob For A Sparco One
WAYNEOLEEDS
Yeah i replaced my standard one, you unscrew the original off then put an adaptor sleeve that should sit over the screw thread of the gear stick, you then place the new gear knob over this and tighten up with an allen key supplied these self tapping tiny screws that bite into the sleeve to secure it without damaging the gear stick underneath.
Hope that makes sense :)
Is it just a twist off one in the aygo? If so which way do I turn?
the same way you'd open a bottle of juice...
Does this apply for an automatic Aygo?
Id imagine so ... i did it and it was a piece of pish to fit :)
