Central Locking
dan96
Hello again,
My central locking won't lock any of the doors, it will unlock them if i lock them manually but not the reverse.
Any ideas please people??
Dan
We had a problem with our corolla not locking and not unlocking, but it only ever happened at home.
I eventually found that the wireless television control from nowstairs to the upstairs tv was jamming the signal.
It does not do it very often, but if l switch all the tvs off at the plug, (we are on a system where you can see sky all around the house via a signal booster and arial wires), so l have to switch off the booster as well at the plug and and the wireless tv controllers at the plug and the jamming stops.
They must be a similar frequency to the car frequency.
You can then unlock, lock the car, ...........switch everything back on and its fine.
Additionally, it may be some other wireless device if you have one that may be causing interference, but l am no expert.
But l guess if it is happening away from home the answer is a different one.
Just thought l would post this incase it may solve your problem.
Best wishes and good luck.
check if all door switch is working properly normally it wont close if a door remain open, just turn the dome light to door position and see if it dim n switch off. if it remains on then u'll have to search for the faulty switch
