Any Ideas And Advice On Modifying My Starlet
lion_fish
Just traded my 51 plate Clio for starlet 1997 (I do believe) and I've already got most things sorted financially but would love some ideas and if anyone has any parts for sale would be a great help.
Was originally thinking metallic purple, carbon fibre bonnet, four spoke chrome alloys with glanza kit on ( the front bumper I am looking at is slightly different to standard glanza bumper but I think is much nicer (will post pic)) car already has some trd additions such as caps here n there stickers etc a bore exhaust and k&n air filter
Any suggestions please do post in need of help :D
Hi matey. The starlets little 1.3 4efe engine can be tuned to give out good bhp. The first thing i would do is sort the handling out as starlets stock handling isn't the best lol. Ill just make a list for each category to make it easy for you mate.
Speed-
Get a Toyota corolla inlet manifold of the bug eyed 1.3 4efe as its a straight swap. This manifold has proven to add about 5bhp and you can feel the kick after about 4000rpm.
If you are confident and will be willing to do some work i would say go for the 4EFTE glanza inlet and throttle body. but this does require work.
Alot of people opt for the cone filter but under the bonnet it gets very hot and the filter gets alot of heat soak, I orignaly had a cone filter but as soon as i changed to a k&n panel filter i could feel a change in acceleration.
Next i would go for a custom 2"cat back exhaust system. costing about £180 but definitely a very good mod.
You can also go for an OBX exhaust manifold but they are very expensive. an alternative would be to go for a corolla 1st gen exhaust mani.
Handling-
The starlets handling isnt the best as you probably know lol. The first thing i did was to get a front strut that you can get of the ep91 (the one you have) or the ep82 model, as both fit. The rear strut will only fit of an ep91 and is a very good handling mod.
Next i would advise to get an anti lift castor kit.
Finally i would say get a rear anti roll bar which improves handling and cornering alot.
Well thats a start :P lol any question feel free to ask :)
Cheers matey :) I will look into these x
