Trc Vsc Lights On While Driving...
The Gent
Morning fellow TOCr's,
Just at work, drop a quick one, On the way to work today, normal driving, my TRC and VSC lights came on, and only when I stopped at some traffic lights and restarted then engine they went away.... anyone know what this is? or had a similar problem before?
Gent.
My car has done this to me once! I switched the car off and back on and have never seen the lights again. Could have been the car having a hissy fit and now all is well?
I would say that if it comes on again get it checked it could be something as simple as a sensor
Strange how some one else had this now , I came online to ask a similar question :blink:
My TRC & VSC & Engine light's are on , but don't go off when I re-start the engine thou....Seems to be running fine still , but i tend not to give it a proper boot just in case. Might just take into Toyota and let them find the code or something ? What do you recon ? Will this be expensive or am I talking £20 - £30 jobby?
Many thanks :D
I think Toyota will charge you an hours labour to diagnose on their machine (hourly rates could be anything between £60 to £100 per hour)
Might be worth seeing if you have a local specialist who could look at it, will probably be cheaper. Before that though if you haven't done so already why not disconnect your Battery to let the system reset
Like danger said it could be nothing I finish work at 5 ifits on again I will let you know, the car drove fine but the lights were on... I only noticed it after a vw r32 pulled up behind me... Lol could it be the car knew and was game for the vw... :P lets hope its nothing mate, toyota may well charge n a arm n a leg!
TBH the TRC and VSC won't affect the car in normal conditions/ driving its when it starts going a little bit wey and a little bit woe when they do their magic :thumbsup:
I remember the good old days without all that electronic interference
It normally shows the lights as a sign of a problem, rather than the fault being with the TRC and VSC itself.
Ive also had the lights come on before - once in the snow where slush and dirt got into the wheel speed sensor, and once on the motorway - restarting the engine cleared the lights straight away.
if youve got a k&n filter may also be worth giving the MAF sensor a quick clean as this is known to throw up an error if it gets oily/dirty.
You could have a look on eBay for a code reader, often arent very expensive and its a useful tool to have
Yep and thats how I preffered it Mr Mooser, nowadays they ruin cars with all this trc vsc asc mumbo jumbo! :(
Rally il have a quick look when I finish work, I dont have a intake yet, getting one next month cnt decide between k&n or apexi :(
K&N!
happend to me twice , 1st time it turned out i had a flat rear .2nd time it was -15 according to the car on the m6 ,xmas eve .
oo ye get the K&N the noise is immense :lol:
Lol anyone know where I can get one cheaper than £170? Thats dear! Lol
Nope no lights today, nothing but a fuel needed which was dropping like a -censored-!!
Called Toyota up yesterday and they said they'd do a diagnostic check on it for £51 , is that decent ? I'll un-hook the Battery this wknd , ( have no tools where i live atm ) needs a spanner to loosen the Battery bolt on's. If this gets rid of the lights , do you recon i should still take it to get checked , because obviously something's up as the lights on mine are still there. :angry:
Called Toyota up yesterday and they said they'd do a diagnostic check on it for £51 , is that decent ? I'll un-hook the battery this wknd , ( have no tools where i live atm ) needs a spanner to loosen the battery bolt on's. If this gets rid of the lights , do you recon i should still take it to get checked , because obviously something's up as the lights on mine are still there. :angry:
no need for a spanner...
Pull out EFI fuse for a couple of mins
Mine went off mate and has not come on since, £51 is expensive surely there must be someone who can do it cheaper?
buy a ODB II reader for your car cheaper than paying toyota 51quid a pop everytime the car has a hissy fit i pay 13quid eBay
http://www.ebay.co.uk/itm/K-N-TYPHOON-INDUCTION-KIT-TOYOTA-COROLLA-T-SPORT-/320733944794?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4aad3b9bda
as regards to the k&n found this might be worth keeping eyes over
i say blitz though sounds the nuts :yahoo:
Lol no worries just checked its around the same price as a k&n, mates got one on his type r, il check it and decide from there
Mine does this to, mines come on, probably nearly 10 times now in the 4months i've owned it. From what i researched, it can be anything, tires too flat? emissions not quite right? balancing out? there are so many things apparently associated with this problem and the obd reader didnt pick anything up when i plugged it in later that day! I need to do a service on it now anyway so im hoping a nice blast of newness might sort it out. But either way i don't think its anything to worry about, i don't even notice it until i look down, car behaves the same so no biggie.
Just get the K&N ,its sounds violent when in lift and also comes with sexci pipin ,im in noway biased :thumbsup:
