Gear Cables
bodrobot
Does anyone know how easy it is to change the cables that go from the shifter to the gearbox?
I have had a look at all the information on 2zzge.com and it seems to indicate that i need to
"1. REMOVE AIR CONDITIONER UNIT ASSY (See page 55–17)
HINT:
Refer to the instructions for removal of the air conditioner unit assy.
2. SEPARATE AIR BAG SENSOR ASSY CENTER
(a) Remove the 3 bolts, separate the airbag sensor assy center.
3. REMOVE EXHAUST PIPE ASSY (See page 15–2)
4. REMOVE FRONT FLOOR HEAT INSULATOR NO.1
(a) Remove the 3 nuts and heat insulator No.1."
Basically do i have to do all the above 1st?
Now i know i should just get under and have a look but i can't today and was just wondering if any1 has done it on here.
