05 Diesel Verso Fuel Filter Location
idler
Hi
Did an oil change today but it started raining again before I could have a look for the fuel filter location !
Could somebody be kind enough to tell me where it is please
thanks baz
  • 1 year later...
It is a similar unit to this one in this video clip...
As far as I recall I only had to remove one intake pipe,unit mounted in a similar position as on video but a little further back because of the car design,I did it the same way...ie removed the unit from the car and used a 'strangle band' metal strap wrench to remove filter!It was Kin tight LOL.
I then refitted to car -ign 'on' and then operated priming pump until went stiff...engine started no probs !
