My Lucida's Acceleration Drops Off When Hits 48Mph
robbiedicko71
Hi, i am new to these forums, so please bear with me.. I am on my fourth lucida but this one has a problem i just cannot work out.. Acceleration does not seem to be right with this one. The pick up is not as good as the ones i have owned before. And when i get to about 48mph the acceleration is worse and takes an age to get up to speed, even if i put the pedal down further.. Sometimes i get some slight juddering but this is not all the time.. I have done the usual and checked the turbo pipes and all is well. The turbo seems to work ok as i can hear the slight whistle form it. I have also blanked off the egr at both ends, ive serviced fluids all over, and replaced the rusty transmission pipes. Still the problem is there.. I do suspect maybe the fuel pump but all runs well when idle. I did also think it could be a faulty turbo pressure sensor... Before i go stripping down anything else, i thought i would scratch some heads and see if anyone can come up with anything as i am sure someone has had this problem... I have no overheating issues or anything like that and no smoke from the exhaust to suspect any head problems as the engine were rebuilt before i bought the bus.. All runs well apart from this little problem and it is bugging the living daylights out of me....
Also i have the common problem with the carbon brushes worn out on the blowers. I have been to my local appliance shop and he states carbon brushes like the ones i need have not been made for years. Toyota do not seem to have a clue and do not have replacements, they want to try and sell me a whole new motor.. Does anyone do these replacement brushes or anything thats updated to replace them if they are no longer made, cos i am screwed without my blowers.. I also need a pollen filter?? or filter that goes in front of the cooler, as again toyota do not do them.
regards Rob
Well what did you do about it?I think this is my first time to hear such a problem like this.
HI Rob and welcome to the TOC. Try putting your post on the Toyota Family Forum on here. Other owners maybe able to advise you.
Welcome in to the TOC Rob, enjoy the club.
