3 Ltr Ssrx Fuel
Surf1969
Does anyone know if a 1994 Ssrx fuel pump would have an ecu that would stop the fuel supply if it went into a fail safe mode ? My fuel pump has no fuel coming out the back after changing the spill control valve and wondered if this could be an ecu problem?
Moved to HiLux/Surf forum
Does anyone know if a 1984 Ssrx fuel pump would have an ecu that would stop the fuel supply if it went into a fail safe mode ?
A mine of info on the Surf forum ;)
