Hi You Guys
tiffannny
Hi and welcome. Which model are you talking about.Why per month?
What could be causing too much fuel consumption.?
The engine is a 1.3 toyota , without any fuel leak, good compression 135 to 150 psi on four chambers. Consumes a approximately a litter of gas per kilometer run. The engine runs normally, with clean air filter, new spark plugs, new high tention wires.
But with LPG it runs about 5 to six kilometers a litter.
Hi has your cosumption of PETROL just increased cos of the colder weather.what tyre pressure are you using.
Post your question on the forum on here for the model Toyota you have.
This section is for introductions only. See warning above Introduction Forum.
