Loose "shield" Half Way Down Exhaust
Notebook
Hi Everyone
Heard a rattling when driving the car, especially when taking off in 1st. Looked under the car 10 mins ago to find a bolt gone on a shield or sleeve that goes around the exhaust.
This has a few holes cut in it, so must have to be ligned up?
I can just about reach it lying on the floor.
What is this? Any info appreciated.
The loose part will be the heat shield around the front box. Needs a new bolt, or otherwise making solid again.
Chris
If working under the car yourself, take all necessary precautions in supporting the vehicle - eg ramps PLUS axle stands. Do not rely on any one means of support, and NEVER rely on single jack of any type.
As above, the wee shield around the cat will give a random rattle and at its worst at, 2500RPM(was on mine anyway). It can be a bit of a mare to remove old bolts. I fixed mine with a few small tack welds to secure it together. 5 min job with the right gear
Jas
My local Mr. T binned mine when it came adrift. Been fine since.
Or you can just undo the nuts and fasten it back on with repair washers. I've done a few including early 4.3s.
Thanks everyone
1 bolt has gone - will have a good look at it tomorrow or sunday..
Nice to see the site is working fine. Last time I was here it wouldnt scroll properly.
Sound like it's about to get sorted! Result.
Chris
"Last time I was here it wouldn't scroll properly..."
This does rather remind me of the famous Morecambe & Wise sketch, where an important and ancient document needs to be brought to a meeting.
"Good evening, Ern. Do you have the scrolls?"
"No no, Eric. I always walk like that..."
A large jubilee clip right round mine cured it.
Phil
Phil
Yeah, they do say that antibiotics aren't as effective nowadays.........
I did what ppg001 did! Cured it a treat.
