Thermostat Tolerance?
ThePermanentProject
Does anyone know the tolerance, either in degree's or percentage, of a bog-standard 82 degree toyota thermostat?
Seems my engine is willing to run up to 89/90 degrees at idle before the fans kick in............
Is this healthy?
The standard thermostat is actually an 82-95 degree stat and can open anywhere inbetween
Sounds just fine to me
Kingo :thumbsup:
