Where Could I Stencil The Engine # Of Lucida?
zalds
To all lucida owners pls help? I just bought a Toyota Lucida (Japanese import from Subic) and I just would like to know where is the engine number of a typical lucida located?
what model is it? if its a 3c-t engine in the rightside if the vehicle (if you're inside the van) open it (unlock) under the tubes near injection pump. very small.
Yeah right, it should be under the former driver side (now passenger). Open the seat upward and unlock the plate. You'll see from the left side under the tube small engraved number and that's it!
