Retrofit Front Fog Lights...
Exvec
??Any done this..is the wiring and switches present..?what would i need to do the job..
Here's a pic showing the front inserts as they stand.
post-131671-0-89584100-1408212601_thumb.
Take a look here: http://www.toyota-tech.eu/Aim/Aim.aspx?pubtype=AIM&menuitem=3
Choose the option as per the attached picture, there are two choice for a diesel model with and with out pre-wiring so it appears there is no of knowing without checking if your car is pre-wired or not.
post-45863-0-11299300-1408213975_thumb.p
Thanks Lee some good info there.
Can i just say that you can look at the wiring by taking off the little bit of grill portion and it ll be glaring at you.
