Corolla 2004 All Speedometer Dials Erratic? Its Not The Clocks
kolobos
My father has a 2004 Corolla 1.4 VVTi and all the dials can be eratic, fuel showing as full, engine hot, 120mph when sat still etc.
There are times when all is ok for a few hours and then the odd dial changes or the fuel shows full, sometimes all the clock illumination goes out including all the dashboard lights for the heater etc., and then they come back on and are ok again for a while?
Does anybody have a clue what might be causing these issues?
So Far
I have replaced the entire speedometer panel for a different one and the problem still remains so I have fitted the original one back.
Checked the connectors at the back of the speedometer panel and all are as new (never touched since the car was new).
Checked fuses and relays to make sure they are seated.
Could it be a faulty relay feeding the speedometer clock panel or indeed a faulty sensor elsewhere?
Any help gratefully appreciated,
Steve...
