Touch And Go Fault Code B15C3
majuku
Has anyone possibility to check whats the code B15C1 I cannot erase from Touch & go diacnostic menu? Cannot find the explanation..thx
B15C1 = No GPS antenna connection ( Open circuit )
Thanks!
Still a bit weird as the sat nav is working and in the hidden menu it finds 7 satellites..?
Do you have a fault or are you just playing?
The "CAR" -menu with fuel consumption etc is empty. I guess it's not a real fault as never even used it but made me curious.
  • 2 years later...
Hi! I have similar problem with my Touch (Panasonic 86140-60150).
I have trouble code  B1579.
Devon Aygo, can you help me to explain this code?
Thanks a lot!
B1579 =  Voice Recognition Microphone Disconnected
  • 4 years later...
hello,
i have this fault code B15C3 and no voice and no volume control can anyone help me my car is 2015 avalon
hi Ali welcome to TOC. I doubt that anyone here can help as this is a mainly UK/European forum & we don't get the Avalon here. Not only that but North American Toyotas & European Toyotas use different infomation systems.
Quick Google threw these up though https://www.google.com/search?client=opera&q=toyota+b15c3&sourceid=opera&ie=UTF-8&oe=UTF-8
It's a speaker short - a blown speaker or damaged wiring
