Auris T180 Boost Sensor?
m700n
look at the front of the engine above the intake manifold and there is a small black pipe that comes off the intake pipe to a small sensor that is mounted on the engine.
Mine has a T-piece on it, but follow the pipe to the left and look for something similar to the black device with 3 wires coming out of it.
Yeah it is. The red is a filter if I remember correctly.
Would it make any difference if I cleaned the filter do you think?
When was it changed/ serviced last?
maybe clean the delicate maf sensor
