What's Needed For A Service On Verso T180
Crispy1
I want to do the service myself as I want know the cars getting the best filters and oil. If anyone out there can tell me what's needed (everything) I would be most grateful?!
Things to consider:
Servicing is due every 12 months or 10,000 miles, whichever occurs first - an intermediate service due at 12 months/10,000 miles, 36 months/30,000, etc, and a full service at 24 months/20,000 miles, 48 months/40,000, etc.
Presume you may wish to change both the oil filter, and air filter.
Brake fluid is due every two years.
Fuel filter every 6 years or 40,000 miles
Clutch fluid first change at 8 years/80,000 and then every 6 years/60,000.
Engine coolant first change at 10 years/100,000, and then every 5 years/50,000 - as regards coolant, use Toyota Super Long Life coolant (pink).
Might wish to change the air conditioning filter (commonly known as a pollen or cabin filter), as this is not part of the standard service, and should be changed as and when needed.
API grade SL, SM or SN
Diesel engines 5w30
Diesel engines with Diesel Particulate Filter or DPNR 0w30 or 5w30 meeting C2 low ash
Brand very much a personal choice.
