reflections off the dashboard inserts
eygo
we have a 13 plate auris Hybrid and the dash board has bluey tinted panels around the air vents with a brushed metal effect
when you sit in the passenger seat on a sunny day the reflections are blinding so i've used a carbon fibre wrap on these panels
to help stop the reflections below are some pictures of the panels wrapped.
  • Like 3
wow.....how did you get it to fit so well?
it took about 20 minutes to cover the panel,i used a panel wipe to remove any polishes
& warmed the panel with a hair dryer before applying ,as you apply the sheet use your fingers to
press the sheet down and to remove any bubbles,you will find at some point you have a fold
i.e. in the corners this is where you warm the sheet with a hair dryer and stretch the wrap & use your
finger to press it down.
for the air vent,i removed the air vent and applying hot air i pressed the wrap into the recess
once in the recess i cut a 40mm circle out of the wrap and continued to apply heat and shaped it until
i could roll the wrap over the lip to the rear of the panel.
total cost about £1.50
Nicely done! Looks like professional job! :clapping:
Toyota will do a foc replacement (with plain black) for the chrome air vent trims on a T27 Avensis that reflect in the wing mirrors - I wonder if they might do similar for Auris?
