Injector removal - issues
onthegow
Hi All. Rav4 D-CAT T180 57 plate
I have issues with an injector leaking gases, I want to remove the injector any tutorials on here. there is lots of carbon deposited around the injector and i,m guessing it must have been leaking for a while, no loss of power so bit strange, I see two other injectors are also starting to leak as I can see carbon deposits.
do these injectors sit on some kind of seat and thats why it's leaking from the underside of the injector!!
any helps would be appreciated. I will try and add a picture
Edited by onthegow
Add images
Has anyone got a PDF repair manual to show me how to remove the injectors and what the torque settings are etc when i put them back in. !!
So I got the leaky injector out. But there is always a but the brass seal is stucknin🙁
I have managed to get the second leaking injector out. Caught it in time and the seal popped out easily.
The other two injectors are in solid😭😭😭😭
so one down 3 to go, one a night so should have it all done by the weekend. Plus I now have a painting job on too. It's going to be a long weeeeeekkkkkkk.
Thsnks for all the info 👍
Success the job is fine 4 X injector seals replaced.
Eirth burying a injector seal remover and a 23 mm spanner to work the injectors free.
Total time 6.5 hours, seals £20
total saving £££££££ worth a little time invested.
Thanks for all your guidance.
  • 4 years later...
Any chance you could tell me more about removing injectors with a 23mm spanner
