Speed Lock
Geert75
I'm from Belgium.
I ordered a speed lock device that you can connect thrue the OBD port.
Today i got a call that is was no longer available.
Does anyone know where i could find such a device?
21 minutes ago, Geert75 said:
I'm from Belgium.
I Googled what you are searching for, and it is for auto locking the doors when the car travels above a certain speed.
My Toyota Avensis has auto door locking which can be enabled/disabled, but having looked at the electronic manual for the Auris, your car does not seem to have it. :sad:
Here are the manuals:
https://myportalcontent.toyota-europe.com/Manuals/Toyota/AURIS_UK_12F26E.pdf?_ga=1.238561920.1686083153.1479550479
https://myportalcontent.toyota-europe.com/Manuals/Toyota/AVENSIS_EE_OM20B44E.pdf?_ga=1.171845024.1686083153.1479550479
Here is where I accessed them from (UK only)
https://www.toyota.co.uk/tme#/my-toyota/eManual
You may need to go to your countries site.
You could test the Toyota method to see if the auto locking can be enabled - Page 82 of the Avensis manual, section 1-2 Automatic door locking and unlocking systems.
Also try other vendors, who may sell the same item - eBay or similar.
