'P shift' warning light
ClaireTJ
I recently bought a 2015 Yaris hybrid - it's my first hybrid and first automatic so I'm still getting used to it. Every so often I have a problem where I can't shift out of P, and the 'P shift' warning light comes on - which seems to be tellng me to put the car into P, but I'm already there! If I wait a couple of minutes and try again, it then works okay. Can anyone tell me why this is happening? Am I doing something wrong? And is there any better way to fix it, rather than just waiting?
Hello Claire - welcome to Toyota Owners Club.
As the car is under it's new car warranty, get the dealer to check it.
Hi Claire,
Are you remembering to press hard enough on the brake pedal?
Ours did something like that last weekend, can't rule out that it wasn't just me.
Prius here. Gotta remember to press brake pedal
Sent from my SM-N9005 using Tapatalk
Keep us posted on how you get on :-)
Sent from my iPad using Tapatalk
Is it a smart start without a key?
Last night ours did the same, and the key light was flashing. I will need to check the Battery, I suspect it is the original Battery and after 4 years it will be starting to fail.
