Verso giving problems ! Help
Toyota 57
Hi
having trouble with a 57 reg verso
fault is difficult to start from cold. It can turn engine umpteen times before firing then. It's runs perfect and starts rest of the day !
Have replaced glow plugs and heater relay , fuel filter , done s c v valve and tried various fuel system cleaners. I also replaced lift pump with a second hand one
should the lift pump always have pressure on the manual pump valve ?
Appreciate any thoughts
Hi there
my old Verso 07 plate won't start during cold morning and I took it to the main dealer and they find out it's the starter motor.
They want around £150 but I went to one of the local reliable garage and got it change for around £70
Since then before I sold my old car it's start off perfectly every time .
Thanks guys 👍
Batter is showing  good volts and plenty kick in it
kitkat do you know if yours had pressure at the lift pump from a while sitting without starting ?
Hi....
i don't think so . mine just won't start while cold weather and took my car to the main dealer to check and find out is the starter motor.
Hope this help
