Attention Previa owners
Phil White
I have just purchased a 2004 Estima Japanese import and need to ask a question to any owners of a Previa 2000 onwards model.
Where is the rear fog lamp switch located please, is it on the stalk or somewhere else. I am asking as our Estima has front fog lamps as well and they are operated from a rotary switch on the stalk which illuminates the rear fog lamp at the same time therefore the rear fog lamp does not work independently of the front. Not a concern as such but i am intrigued to know thank you.
Hi, not many Japanese imports have rear fogs. You are a lucky one. Most imports have retro fitted rear fogs and a dashboard switch.
Since your bus is over 10 years old it doesn't require the same Government SVA examination as other recent imports do so that is lucky and the fact it operates both lamps with one switch is certainly useful too.
