Audio from usb. Touch 2 with go.
MIC_ool
Hello guys. I use usb stick as a source for my audio and found out that every time I turn off the ignition and turn it back on, music won't continue from moment where it was before. Sometimes it will play random song from the same album or will play different album. Is there anything I can do to change the way it plays the music? Cheers
No you can't the head unit requires the connected device to memorise its location which an un-powered USB won't do, using an ipod or mp3 player overcomes this
Wow, this is a downgrade from the earlier version (Touch and go) which resumes usb mp3 songs.
