Lambda problem
Kylurox
Hi. I have a problem with lambda sensor. Some mechanic change a orginal sensor for some cheap one and work for some time but i want to chnge for orginal denso and i cant find what is a orginal part number. Sonda is before cat. Sensor one bank one. Some one can help me and give me a pajk number ?
So the probe is broken and you want to replace it, or it's still working, but you want original part?
What engine do you have in your car?
You can try vin based search on http://japan-parts.eu/
