led xenon
Vasilisspyder
hello, i am looking for led xenon for my yaris 2018 with a headlight like the photo.
i want the led that will provide a good light that is like a line on the horizon and its no light over the horizon (i dont know if you understand me) no spread in different directions.
What type of bulb does it take. Most have a replacement LED. My auris has h11 and the LED bulbs i fitted are 30w each and have excellent light output and the control/cut off you describe is excellent too. I`ll probably have to stand on the naughty step for suggesting LEDs.
Indeed. 😛 It should fail an MOT if presented with them fitted in a light unit not approved & E-marked for them.
MOT....non UK member.
Yes, but you are in Yorkshire and you say you've fitted LEDs.  Are you MOT compliant and legal?
Mick
but you & your car are in the UK.
if the op is in the EU (which admittedly we don't know) they are all meant to have equivalent legislation re. lighting.
