Gearbox Question
Colin J.S
I have a petrol Aygo 2007 with manual gearbox which needs replacing. Does anyone know if the gearbox from the later Aygo is the same please?
You can use any gearbox from a 1.0 manual from 2005-2014, you cannot use one from a mk2 2014>
Thanks Lee.
Much appreciated. I notice re engine numbers, a lot seem to be 1KR EF but mine just says 1KR, is there a difference please?
I think people are mixing up the engine code the aygo uses a 1KR-FE engine, no difference
