Warning lights all lit up
Ianlarkrise
Driving along and suddenly all of the warning lights came on, then they all went out except 3, engine, tyre pressure and anti slip.  Engine got less power.  Stopped checked everything, especially tyres and no problems, nothing.  Started up and everything was normal. Does anyone know what the problem  could be?  Many thanks
The diverse nature of warning lights means that there is a common denominator. Check your car's negative/ground connection.
I had the TPMS, VSC and engine management lights come on and stay on. Turned out to be one of the O2 sensors.
