Aygo Reversing CPU Module Replacement
swain90
I'm needing to replace the Reversing CPU module on an Aygo, as waters got into the unit due to being install incorrectly.
I've removed the unit and I believe the part number is: PZ464-X2423-01, however there is another number 4M0174T5P (these are the two numbers printed on the front of the module).
I'm struggling to find a direct replacement for PZ464-X2423-01 (presuming that is the part number). Am I searching for the right thing/does anyone know if there's an equally compatible part number I could search for instead?
Cheers,
Swain90
You can try going to japan-parts.eu and entering your VIN, then finding the part, maybe it will give you some alternatives.
